Quels fichiers puis-je supprimer?
infoamat
PowerBook de Bois
PowerBook de Bois
MessagePosté le: Dim 06 Sep 2009 à 9:49    Sujet du message: Quels fichiers puis-je supprimer? Répondre en citant
onsoir,
dans mon dossier préferences de mon macbook j'ai quelques fichiers .Plist suspect mais je n'ose pas les suprimmer.
Voici les fichiers:
Audio-->com.apple.audio.DeviceSettings.plist
com.apple.audio.DeviceSettings.plist~orig
com.apple.audio.SystemSettings.plist
com.apple.audio.SystemSettings.plist~orig
com.adobe.acrobat.pdfviewer.plist
com.adobe.PDFAdminSettings.plist
com.apple.AirPortBaseStationAgent.launchd
com.apple.alf.plist
com.apple.alf.plist~orig
com.apple.AppleFileServer.plist
com.apple.ARDAgent.plist
com.apple.BezelServices.plist
com.apple.Bluetooth.plist
com.apple.ByteRangeLocking.plist
com.apple.CoreRAIDServer.cfdb
com.apple.dockfixup.plist
com.apple.driver.AppleIRController.plist
com.apple.headerdoc.exampletocteplate.html
com.apple.HIToolbox.plist
com.apple.iLife08.plist
com.apple.iLife09.plist
com.apple.iPod.plist
com.apple.iWork09.Installer.plist
com.apple.iWork09.plist
com.apple.java.util.prefs.plist
com.apple.loginwindow.plist
com.apple.mediaio.DeviceSettings.plist
com.apple.nat.plist
com.apple.pcast_integration.plist
com.apple.preferences.accounts.plist
com.apple.RemoteDesktop.plist
com.apple.RemoteManagement.plist
com.apple.ReportMessages.domains
com.apple.security.systemidentities.plist
com.apple.SetupAssistant.plist
com.apple.SoftwareUpdate.plist
com.apple.TimeMachine.plist
com.apple.windowserver.plist
com.apple.xgrid.agent.plist
com.apple.xgrid.controller.plist
com.install4j.installations.plist
com.lobotomo.MacProFan.plist
com.stuffit.agreement.plist
com.stuffit.Engine.plist
DirectoryService-->ContactsNodeConfig.plist
DirectoryService.plist
DirectoryServiceDebug.plist
DSLDAPv3PlugInConfig.plist
DSRecordTypeRestrictions.plist
SearchNodeConfig.plist
FLEXnet Publisher--> adobe_00080000_tsf.data
org.cups.printers.plist
Parallels---> dispatcher.desktop.xml
licenses.xml
network.xml
vmdirectorylist.desktop.xml
SystemConfiguration--> com.apple.airport.preferences.plist
com.apple.Boot.plist
com.apple.nat.plist
com.apple.network.identification.plist
com.apple.smb.server.plist
NetworkInterfaces.plist
preferences.plistv
Voilà, il y en a qu'il me semble bizarre du genre: parallels que j'ai désinstaller idem pour Iwork ainsi que iLife08 et stuffit
Merci d'avance pour vos réponses
MessagePosté le: Dim 06 Sep 2009 à 9:54    Sujet du message: Répondre en citant
tu peux tous les supprimer si tu rencontres un souci, ils se recréeront au prochain lancement de ton Mac.
je te conseille de les laisser si tu n'as pas de souci, car cette manip ne te servira à rien.
MessagePosté le: Dim 06 Sep 2009 à 10:39    Sujet du message: Répondre en citant
une désinstallation d'un logiciel n'efface jamais ses fichiers .plist
pascalformac
PowerBook 190
PowerBook 190
MessagePosté le: Dim 06 Sep 2009 à 11:35    Sujet du message: Répondre en citant
Attention
comme conseil global j'inciterai à plus de prudence que les conseils du dessus
ne PAS toucher
( quand on ne sait pas ce qu'on touche et pourquoi on touche , on touche pas)
Car selon ce qu'on touche et comment ca peut signifier cata en vue
( et dans certains cas nécessité de reinstall va DVD de certaines choses tenant à l'OS)
ce sont des fichiers de fonctionnement, essentiels à l'OS
en cas de panne, certains peuvent etre remplacés , et selon des manips précises
donc
tant que tout va bien tu laisses
Et si une panne apparait un jour avec une fonction on avise sur la manip appropriée avant de faire une bêtise regrettable
( je songe entre autres à des purges à la louche dans la biblio OS...)
MessagePosté le: Dim 06 Sep 2009 à 11:44    Sujet du message: Répondre en citant
En règle générale, tous les fichiers .plist dont le nom commence par com.apple ..... sont à laisser tant que l'ensemble du système fonctionne correctement. Le dossier SystemConfiguration est à laisser intact car il contient les paramètres communs à tous les comptes utilisateur (même invisibles), sur les ports de communication etc dont se sert le système pour le fonctionnement général de la machine.
MessagePosté le: Dim 06 Sep 2009 à 11:48    Sujet du message: Répondre en citant
on tombe donc bien tous d'accord, on n'y touche que si souci ! Wink
pascalformac
PowerBook 190
PowerBook 190
MessagePosté le: Dim 06 Sep 2009 à 12:13    Sujet du message: Répondre en citant
@infoamat
laisser tout comme c'est
et n'agir qu'en cas de besoin et avec les bons fichiers et de la bonne manière.
@chvox
là où j'avaisi tiqué ( et j ne suis pas le seul) c'est sur ton léger
on peut tous les supprimer si souci
techniquement ce n'est pas faux , mais le mode de suppression peut avoir des conséquences divers
(relire l'apport de blackjmac qui donne un bon exemple)
MessagePosté le: Dim 06 Sep 2009 à 12:21    Sujet du message: Répondre en citant
pascalformac a écrit:
@chvox
yes pascal Wink
