Cyrillo PowerBook Duo 230
Posté le: Sam 05 Sep 2009 à 12:55 Sujet du message: |
saft ça fait quoi exactement ??? _________________ Macbook Pro RETINA 15 1TO SSD 16GO RAM
OS X EL CAPITAN
Posté le: Sam 05 Sep 2009 à 13:07 Sujet du message: |
j'ai des plantages avec snow, ical voir safari (a quitté de manière imprévue)... avec le triangle jaune avec ! blanc... _________________ Macbook Pro RETINA 15 1TO SSD 16GO RAM
OS X EL CAPITAN
Posté le: Sam 05 Sep 2009 à 13:14 Sujet du message: |
Cyrillo a écrit: | saft ça fait quoi exactement ??? |
Citation: | Ad/banner blocking with simple URL pattern matching
Add bookmark folder here and add bookmark here in every bookmark menus
Always open browser window in tab
Auto hide Downloads window
Auto save and restore opened browser windows at quitting and start
AutoComplete always on
Block animation
Block HTML refreshing in front-most browser
Block images and plugins
Bookmark search
Bookmark this group of tabs
Consolidate browser windows
Control-1 to 9 to popup bookmark menu or open bookmark
Control-drag page
Crash protection
Create dated folder for downloaded files
Customizable HTTP timeout
Customized Google search field
Do not allow scripts to bring tab to front
Drag tab buttons to add the URL string to other applications
Enter/ctrl-enter to go to next/previous links (like in Google)
Export Selected Bookmarks
Extended search from contextual menu
External text editor support for TextArea
Fix for Frame Creation Attack
Fix for Safari AutoFill Information Disclosure
Focus the last selected tab when closing the current one
Full-screen browsing
Google Safe Browsing
Growl support
History search
Install debug menu
Kiosk mode
Max screen for normal browser windows
Modified "Open in Tabs"
One-page PDF export
Open tab in new window
Option to use Aqua interface
Original URLs in Spotlight comments of downloaded files, exported PDFs and saved pages
Plain copy
Print All
Reload All Tabs
Reversed tab order
Save and load browser windows
Save tabs and save all
Separator in bookmark menu
Shortcut for Look Up in Dictionary
Sidebar
Sort bookmarks in every bookmark menus
Stop download warnings
Tab rearranging with drag and drop
Tab search
Tab thumbnails
Type-ahead searching
Undo support for closing tab and closing other tabs
URL shortcuts
URL traverse with return-key
Work-around of click-through bug in WebKit |
Posté le: Sam 05 Sep 2009 à 13:59 Sujet du message: |
j'ai voulu lancer onyx mais pas compatible snow.je vais donc attendre la prochaine version. _________________ Macbook Pro RETINA 15 1TO SSD 16GO RAM
OS X EL CAPITAN
Posté le: Sam 05 Sep 2009 à 21:37 Sujet du message: |
Cyrillo a écrit: | safari est mon navigateur par défaut mais firefox j'en ai besoin par exemple pour ebay car lors de création d'annonce pour mettre de la couleur etc... il me demande de mettre du langage html et firefox non. et aussi sur firefox j'ai une option de mot de passe principal bien utile qui n'existe pas sur safari et dernier point lors du téléchargement safari ne me propose pas de choisir l'endroit ou mettre le fichier "toujours demander où enregistrer les fichiers" (je dois choisir un répertoire obligatoirement) sinon je le dégagerai car c'est clair safari il est super rapide |
suis d'accord avec toi, chez moi, Firefox je l'utilise pour ma déclaration d'impôts. _________________ Vincent
Posté le: Sam 05 Sep 2009 à 21:44 Sujet du message: |
c'est vrai le mot de passe principal je trouve ça utile, ça n existe pas sur safari dommage... _________________ Macbook Pro RETINA 15 1TO SSD 16GO RAM
OS X EL CAPITAN
Posté le: Sam 05 Sep 2009 à 21:48 Sujet du message: |
c'était surtout pour un souci de certificat non compatible.... _________________ Vincent
Posté le: Dim 06 Sep 2009 à 8:31 Sujet du message: |
love_leeloo a écrit: | http://gizmodo.com/5346418/snow-leopard-review-lightened-and-enlightened |
tiens, un nouvel article :
http://gizmodo.com/5352889/mac-os-x-snow-leopard-the-complete-guide _________________ Vincent
Posté le: Lun 07 Sep 2009 à 9:00 Sujet du message: |
tiens depuis que j'ai installé 10.6, lorsque je mets mon ordi en veille (en le fermant), et bien 1 min après il sort de veille pour y retourner instantanément. et cela toute les min au moins ....
pas de souci de votre coté ? |
PhilippeL PowerBook Duo 210
Posté le: Lun 07 Sep 2009 à 9:40 Sujet du message: |
pour moi tout roule, j'ai juste "perdu" quelques économiseurs d'écran ...  |
Posté le: Lun 07 Sep 2009 à 10:39 Sujet du message: |
pour le souci de veille :
Dans MacintoshHD/Bibliothèque/Preference/SystemConfiguration
effacer le fichier com.apple.AutoWake.plist
Mais attention il arrive que ce fichier réapparaisse, du coup il faut à nouveau l'effacer !
Posté le: Lun 07 Sep 2009 à 14:46 Sujet du message: |
bah, j'ai viré les savers ... à l'occasion j'installerai de nouveau et j'essaierai ta manip' Merci ! |
Posté le: Lun 07 Sep 2009 à 15:02 Sujet du message: |
nan, pardon, la manip est pour MON pb
pour le tien, il suffit de mettre les prefs systeme en 32bits |
Posté le: Mar 08 Sep 2009 à 0:14 Sujet du message: |
love_leeloo a écrit: | pour le souci de veille :
Mais attention il arrive que ce fichier réapparaisse, du coup il faut à nouveau l'effacer ! |
j'ai pas eu ce souci, on n'en connaît pas l'origine ? (qui crée ce fichier ?) _________________ Vincent
Posté le: Mar 08 Sep 2009 à 8:19 Sujet du message: |
non j'ai regardé vite fait les forums, et j'ai trouvé ça, je n'ai pas approfondi |
Posté le: Mar 08 Sep 2009 à 9:30 Sujet du message: |
love_leeloo a écrit: | nan, pardon, la manip est pour MON pb
OK ! Merci m'sieur  |
Posté le: Mar 08 Sep 2009 à 10:02 Sujet du message: |
par contre tu perds l'utilisation des screensaver 64bits  |
Posté le: Ven 11 Sep 2009 à 20:36 Sujet du message: |
heu et on fait comment ça ?!? |
Posté le: Ven 11 Sep 2009 à 20:38 Sujet du message: |
trouvé !  |
Posté le: Mer 23 Sep 2009 à 8:59 Sujet du message: |
Bon, alors les savers fonctionnent si on les lance manuellement, sinon, nada ! |
