Posté le: Jeu 01 Mar 2007 à 9:02 Sujet du message: |
Une chance oui. _________________ Ludovic
mamiemacon PowerBook de Coton
Posté le: Jeu 01 Mar 2007 à 12:49 Sujet du message: |
violon2 a écrit: | waow, et il faut être dans quel cas précisément ?
Le mien: Ibook G3 700 , UV2381GYLQ3
une chance ou pas ? |
UV117XXXXXX à UV342XXXXXX : dedans !
Voici l'extrait de la note qui circule ( peut être un fake ), mais cela a le mérite que désormais les CMAA re-prennent les choses en main :
Eligibility for Expanded iBook Logic Board REP Ends for Many Units
APPLIES TO: Asia-Pacific, Canada, Europe, Latin America, United States
Also applies to Japan
Eligibility for the Expanded iBook Logic Board Repair Extension Program (REP) has ended for many of the iBook models noted below:
iBook (Dual USB)
iBook (Late 2001)
iBook (14.1" LCD)
iBook (16 VRAM)
iBook (14.1 LCD 16 VRAM)
iBook (Opaque 16 VRAM)
iBook (32 VRAM)
iBook (14.1 LCD 32 VRAM)
Note: Complete details about the Expanded iBook Logic Board REP are available in the Knowledge Base document Repair Extensions Programs.
The Expanded iBook Logic Board REP is a worldwide program covering repair or replacement of the main logic board in specific iBook models manufactured between May 2001 and October 2003 that are experiencing specific component failures. The Expanded iBook Logic Board REP covers affected iBooks for three years after the first retail sale of the unit.
APPLE will no longer accept Expanded iBook Logic Board REP CompTIA Codes for the iBook models noted above on and after 10 October 2006. _________________ Alu 12" 867Mhz |
